DEcosse
If it's no Scottish it's CRAP!
Was looking for something different on EBay and just happened across this product by company called Blue Sea
OK - hands up - how many of you have a bunch of accessory ring terminals stacked up on both sides of battery?
I was seriously impressed with that - so simple yet so effective
The Positive side is especially nice as is not only a buss, but also gives you 4 separate Fused Outputs without requiring one in-line for each of your accessories
Lots of listings on Ebay
Note that the 5024 includes BOTH terminals while the 5023 is Positive ONLY - so be careful which you order
Incidentally my immediate thought was "why didn't the PDM60 come with at least that negative one, rather than the pigtail and nut/bolt?"
(actually the Negative one just about anyone could make that as a DIY)
The only slight criticism is the stud size is more aimed at car batteries - but a washer on the stud will help that. I've actually sent them a product suggestion for similar aimed more at the Motorcycle Accessory market, bit more compact with ATM size fuses and a smaller M6 Battery Terminal attachment.
I haven't bought one yet, but I have to give this two thumbs up!
ST Blade Battery Terminal Mount Fuse Block Kit - Blue Sea Systems
Compact ATO® / ATC® fuse block consolidates branch circuits and eliminates the tangle of in-line fuses for electronics and other appliances.
www.bluesea.com
