Hey Wrecka, just a thought, look up under the rear fender and make sure the tyre hasn't rubbed against the wiring, I know mine and a few others have had that happen.
@Wrecka trace the tail light wire back to the first plug-connection, unplug it and check with a test light if you have power to there. (With the lights on)
@Wrecka trace the tail light wire back to the first plug-connection, unplug it and check with a test light if you have power to there. (With the lights on)[/QCheers mare ill give it a go
Mine were as well, when once I took apart for a tire change and found all taillight and signal wires bare of all insulation from the tire occasionally rubbing from crappy rear shocks.
Was astounded they even worked!
Worth giving a GOOD look, M8!
