I am not getting power to my headlights. Checking my EB fuse box I have no switched power. The constant power is fine. I have the EB headlight relay. Im not much good with electrical stuff so looking for help on where to start chasing the problem down.
Likely a ground or positive terminal problem> Make sure the contact points are clean and tight. There should be two relays so if both are out its a common.
