Stock and TORs
Can you run the TORs and stock air filter without the ECM download?
Yes you can do it.
You can run a full Jardine exhaust on the stock map.
It is not the approved solution, and you are giving up a good bit of performance with so many decent aftermarket maps to choose from on the TuneECU site.
You and I have emailed and I have the TORs coming. I'm trying to figure out how I can get the triple K&Ns, Crossover pipe, and TORs installed and you tune the bike as low cost as possible. I still have to get a hitch. If I put on the TORs now, will they sound the same as they would after your mods? I want to be sure they are what I'm looking for before I have you tune for me. I want deep sound. I have a lot of Harley friends. They are already saying it sounds like a Goldwing.
Bahaha id just say it shouldnt concern u how it sounds as i doubt u will here it from so far behind me anyway
Cheapest way would be to get rid of the Hardley Friends ?
Problem solved
Just kidding
Hi you may have some problems .......... I am running Tors and standard air filter ...just had a service and the dealer downloaded a standard tune . it was ok for a time 150 miles there was a lot of popping on over run which i did not mind ,then the missfire showed up ... took it back to the dealer reloaded the wrong tune again so it run for a time then F***** about ....... when they put the right tune in it was like finding a long lost friend very nice to have it all back to normal...
so you may have one or two problem if you donot put a tune in for the TORs..
