Stebel Nautilus Horn
It says 20A in the specs Mark
Specifications:
  • Sound Output: 120 dB at 3 feet
  • Current Draw: 20 Amp
  • Dimensions: 5.4” (137mm) wide x 4.5” (116mm) high x 3.6” (86 mm) deep
  • Stylish All Black Design
But you would need to use a relay anyway, so even if the power feed is coming direct from battery, the relay's coil can still come from a switched source
i.e. terminal 86 from an ignition-switched power source (original horn positive feed) and terminal 85 from your horn button (original horn negative); then 30 from battery and 87 to the horn compressor positive; and of course the horn needs to be grounded (either engine ground or battery negative). Remember you need decent wire gauge for 20A and the negative side needs to be sized similarly to the positive.
For the low-current coil feed wires, these can be small - 20 ga or so.
i.e. Ignition still needs to be on for the horn to work, even though high current source is fed from the battery
Thanks DEcosse,
Much appreciated,
Mark Dunn
Ken,
1) Why can't they both work at the same time?
2) Pardon my ignorance, but is that square with 85, 86, 87 & 30 the relay you speak of?
1) You will never hear the stock horn when the Stebel goes off.
2) That is the relay
May I further trouble you for where and what to find this relay?
As I explained earlier, if you use the PDM60, you don't need the relay (assuming you did not use the negative trigger for something else)
