Stator Change
QwiQR3
Freedom
'16 R3R "Edith"
Greetings, will someone tell me how to get this cover off? The frame is high enough. Its the right lower i cant get around frame
Per the shop manual it requires engine removal to replace the alternator. Engine removal is 38 steps and is detailed starting on page 10.2 of the manual. Engine refit is the next section. Just as a heads-up you actually remove the frame from the engine and not the engine from the frame.
