Starmanut
Nitrous
- Joined
- Jun 12, 2017
- Messages
- 1,112
- Location
- Spanish Fork, UT
- Ride
- 2010 Rocket III Touring, Suzuki Boulevard M50
Hi everyone.
I bought a 2010 Triumph Rocket 3 Touring with 20,000 miles on it about six weeks ago. Just getting used to it and starting to like it. I installed a tachometer on it right away and rode it for about 400 miles or so with no problems till about last week when I had this strange thing with the display and tachometer. When I was riding along or stopped at a light idling, the tachometer maxed out at 8000+ RPM, and the instrument display went crazy, for lack of a better explanation. The speedometer went to zero, all the warning lights were flashing/flickering on and off, the clock and led displays went crazy or just went blank. The engine was cutting out when this was going on. I was able to turn around and make it home, the last two blocks everything worked fine.
I have not had the bike very long before installing the tachometer so I haven’t had a chance to get a feel for things. I removed the tachometer connections to see if it might be the problem (it wasn't). The next day everything seemed normal. I took it out for a block, forgot my phone so I came back and turned it off. Then when I turned the ignition switch on I got nothing! I just took everything apart and checked the battery and connections, reconnected the big plug under the tank that goes to the speedo and display and I still get NOTHING when I turn the ignition on. Help. I’m about ready to kick this thing to the curb and go back to my trusty Kawasaki. (or take it in to a dealer to fix it, but HOW to get it there. Ugg. They are all about 50 miles away.)
Anybody out there that has had this happen? Is a Triumph shop my best bet?
Thanks!!
PS. It looks like the ignition switch is buried under the frame and way hard to get to (if that might be the problem).
Thanks!!
