Sissybar Removal and Mudguard Covers
Yes correct and if you had the separate passenger seat that plat your going to remove is also the one that is permanently mounted to the seperate passenger seat used with your solo seat if you also want two up. But to be honest its not as comfy for the passenger as the dual seat you have.
here you go a shot of your seat with the separate passenger seat. top view
bottom view note how the mounting plate resembles yours only it is permanently attached to the passenger seat. then it bolts right where the plate is that your removing it is the same only it does not have the rear latch as the unit bolts to the bike. You simply bolt or unbolt it if you want to go solo or dual. The main seat pan has the same latch on both.
bottom view
you will be just removing the plate on your which has the rear latch and then put the bolts back into the fender frame.
Hope this helps
YEP!! Thanks!! Only difference is the seat I have on now is a one piece seat. But I get what you are showing me.
