Claviger
Aspiring Student
- Joined
- Jul 25, 2014
- Messages
- 6,934
- Location
- Olympia Washington
- Ride
- '21 Z H2, '14 R3R, '02 Daytona 955i
How do you tell if your on the compression stroke when you are set to TDC?
Set the crank mark to lined up, that's TDC for #1. Look at the cams, if the exhaust is rolling off the valve pointing at the exhaust and the intake is rolling onto the valve pointing towards the intake that is the beginning of the intake stroke. If the exhaust lobe is pointing generally up and away from the valve that'll be end of compression/beginning of power stroke.
