Sidecar Flip
I was working on a large truck and had to replace the reluctor plate on the flywheel because someone decided to replace their own clutch. The plate was horribly bent and the crank sensor couldn't read it. In order to pull the tranny I had to drop the exhaust system. And drop it I did, it fell and about a half inch bolt punched a nice hole in the left side of my skull and you can actually see my brain in there.
Sooo, since I don't need a skull or a brain to go to ES I'll still be going![]()
Wow Tomo......
Reluctor plate....sounds like something from Star Wars.....
I certainly hope you are ok. I have an assortment of plug buttons if you need one to cover the inspection hole....in your skull, that is... Various finishes too..chromed, black anodized, wrinkle finish black and wrinkle finish grey. If you want, I'll bring along my Hawkeye bore scope, it will fit in my saddlebag. We can all take turns looking inside. It will view, in high resolution, 180 degrees from center so we can inspect your wrinkles......
In fun, of course. I just hope you are ok. I was always under the impression that your brain floated in a semi liquid. Are you so old it's dried up?.....Gwad, there I go again.
Keep us all apprised of your condition.
