Chariot
.060 Over
- Joined
- Jan 24, 2021
- Messages
- 138
- Location
- Glasgow Scotland
- Ride
- 2017 Rocket 3 R modified trike to take wheelchair
Is there anyone out there who is knowledgeable about the ford sierra diff commonly used in UK trikes built since the Rocket3 was introduced. My problem is I think my trike is pulling too high a gear through the diff. We measured the ratio at 3.125, could possibly have been 3.2. This ratio probably works ok with normal trikes but as my trike is carrying a wheelchair it is lugging 200kg between chair and passenger. As a result of this unless ridden carefully it is prone to destroying clutches in a few thousand miles. So far I have tried every clutch and ended up with Barnett with stronger springs and shims under the bolts. This is ok but you can't boot it away from the lights. i was thinking of having a lower ratio fitted to the diff. Maybe 3.6. Or is there anything available in-between 3.2 and 3.6. Any help would be greatly appreciated. I have talked to Cassava trikes but they no longer use a sierra diff having moved to BMW
Cheers
Kenny
Cheers
Kenny
