Triumph Rocket III Classic or Roadster 05-13 VITON Valve seals set of 12
Price:
US $36.99
Approximately AU $46.04 Buy It Now
Postage:
US $6.97 (approx. AU $8.68) USPS First Class Mail International
This Auction is for a brand new set of 12 VITON valve seals to fit the Triumph Rocket III Classic/Roadster from 2005-2013 yrs. These are some of the best seals on the market!! These are brand new production seals. Viton seals hold up to heat much better than rubber seals with less fricton as well due to 5% teflon. We also have these for most other Motorcycle engines if needed, so check out our other auctions.
Part No:
SSI-TR3VS
He's asking about the steel sleeves that the valve stems ride in. They're either cast or pressed into the aluminium head. Not sure how the Rocket engine is set up in this regard though. May be in the factory service and repair manual?
Thanks @RevRoss I thought they may have been the solid steel sleeves you suggested but had not come across any without searching for them, but had seen these a while ago. You would need a hell of a lot of miles or a damaged engine to need the steel guides I imagine.
After our conversation I thought "I've got some photos some where"
Found them.
I would say that the guides are pressed in.
Head warmed, guides cooled. Drop them in.
The service manual says that “due to assembly methods used, the the valve seats and valve guides cannot be replaced”.
I am not that much a mechanic to no if this is really impossible.
