Haylo
Standard Bore
- Joined
- Jun 11, 2022
- Messages
- 7
- Ride
- R3
Hi there everybody, I am in the process of recommissioning a friends Rocket 3 Classic which has been laid up for a while, carried out a service, fresh oil, oil filter, new spark plugs, removed air & fitted a ram air filter system. Fitted a new fully charged battery, switched ignition on lots of whirling sounds dials swept, mil light on, main beam warning light on, low fuel warning light on etc, went to press starter button NOTHING Good start, so I starting checking things, did a diagnostic check with my Dealertool programme result was 14 fault codes At this point i muttered a few words to myself, so took the starter motor off bench tested it all working, checked starter/cross over relay located next to the flasher unit found to be faulty so replaced still no start. Check all fuses/relays sprayed electrical cleaner on all connections still no start, checked side stand switch since purchase an eliminator plug, checked clutch switch relaced complete left hand switchgear as clutch switch fell apart still no start Found main harness had been spliced/cut & scotch lock joiners used so I replaced the main harness with a used harness, still no start. So next step was to look into the fault codes one by one I rectified these & did a re test scan all cleared now. My dilemma now is why no start? I've checked the crankshaft position sensor as this came up a as fault code all good now, went to starter/cross over relay all seemed good checked all wiring individually seem good but still no start? accidentally I allowed the wire (Yellow/brown) from the relay to the Ecu pin B24 to touch the chassis frame whilst pressing the starter button & the engine turned over? Took the lead away from the chassis, back to no start wtf. Whilst cranking over the engine the main beam warning on the dash cluster remains on all the time go figure, switch gear position makes no difference high or low beam lights work as normal the same when I crank the engine over with the yellow/brown wire touching the chassis press button lights goes out release button lights come back on. Anybody got any suggestions. Regards
