Fastmike
Storm 3 R
Hi Gents
I was looking for a Lithium battery for my Storm to gain some kilos as I did on other motobikes, but realized that strangely, there are none referenced whenb you search by bike model.
I am able to find replacement if I search for the model of battery, but again, if I search by bike model, those results are not showing up, like if there was a compatibility issue...
Is there a reason for that? Voltage generated too high?...
Thanks
Phil
I put this in my 2024 GT. Very happy with the way it cranks the bike. Much stronger than the stocker. Which was brand new. I put it in to save weight. Maybe about 5 lbs. My ATV needed a battery, so in went the OEM Rocket battery. Antigravity XPS V-12 Lithium Battery - Left Side Negative Terminal Double check the terminal location though. I seem to remember having to bring one of the cables across the top of the battery to get it to reach. Maybe right side negative was needed. It was a year ago, and I cant remember exactly.
If the original battery was AGM (acid glass mat) then the rectifier and stator are sized to recharge that as well as supply 14.4 VDC to the system. The LiOH batteries take a slightly higher voltage to fully charge. It's possible to have rectifier problems when putting a lithium battery in, so be careful and do your research beyond the weight savings.
Ive only ran my anti gravity battery fir 7 years with 0 issues, seems the rocket is ok with it, hasnt had any issues electricly since installing this beast. Anti gravity facts from them below. Best batteries ive owned. The one on drag bike slaps it awake immediately and its tiny. The one on my bike is 900cca and they dont offer any longer. 300 and forget about it.
I bought two of these. I have 3 bikes with Antigravitys. Amazon.com
