barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
Aha - Thanks Wayne.You can't get AFR via OBDII on the Triumphs because they are not operating closed loop using a wideband Lambda sensor.
So like Ian said. If we whack a wideband in with or without separate controller - can the signal be fed into the Rocket ECU? and be used correctly. Basically it's just a voltage right?. I know the AEM-UEGO has an aux output. Not sure if the Powerdex does. All the other info is there and the unit I have records hours and hours of data.
I'm planning on buying a wide band anyway. May as well kill two birds with one stone.
