Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,745
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
I recently removed my back wheel for tire replacement and low and behold my wheels bearing are bound up again. I've been reading about people shortening the spacer. I don't agree. I've attached a drawing from All Balls on bearing installation with spacer. In the drawing the "fully seated bearing" would be the one on brake disc side, that's held in place with a circlip. The bearing on the cush drive side, should only go in until it contacts the spacer, and not all the way until the outer race seats. As an experiment, I used the axle and some spacers to simulate the wheel being in the bike. As soon as I tightened up the axle the bearings moved freely. What does this all mean ? I believe because the center spacer is aluminum, it's soft enough to squeeze a little bit under pressure. When the wheel is put in the bike and tightened down, the center spacer compresses a little bit and lets the cush drive side bearing move in a little farther. Everything works fine until you loosen the axle and the spacer becomes uncompressed. It then pushes outward on the bearings enough to bind them, but not enough to move the bearing back out. This is my opinion and may not reflect the general view of R3 owners.net or any of it's subsidiary's
