"BREAK IN PROCEDURE All ring and pinion sets require a brief break-in period to ensure long life and quiet operation. The following break-in procedure is recommended before heavy load and constant usage. 1. Bring axle to normal operating temperature by driving vehicle for approximately 15 to 20 miles. Do not create any shock loads. Do not tow or carry a load with the vehicle. 2. Let the axle assembly cool completely. Do this 2 –3 times. 3. For the next 200 miles of operation, drive gently, without any heavy loads. 4. For trailer towing, an additional cycle of 15 to 20 miles break-in is required with the trailer after step #3. This is important! To properly break in a new gear set, 200-300 miles of normal driving is recommended before constant towing."
I drove 20 miles just pulling the trailer so today I'll load up the SxS and pull it 20 miles then the break in should be done. I'm at 350 miles total, I've done all the steps except loading the trailer and towing.
Seems like a lot considering you don't do this when they are new.
