Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,969
- Location
- Ride
TRIUMPH Rocket 3 Classic Exhaust Flange Covers TR3012 Fits OEM Reference # A9738115. Clearance Price!
Price: £19.99This set of 3 covers bolt's on in minutes and completely cover the unsightly blue and brown discoloration of the exhaust pipes between the engine and the stock chrome heat shields.
What an improvement! Once you see how much better and finished the exhaust looks with these covers installed you'll wonder why it didn't come this way from the factory.
After market Part. TR3012 : Fits OEM Reference # A9738115
This set of 3 covers bolt on in minutes and completely cover the unsightly blue and brown discoloration of the exhaust pipes between the engine and
www.squaredeals-ltd.co.uk
Rivco Products Magnum 118Db Electric Horn Set ELCHRN : Discontinued Stock Clearance!
RRP: £Our Price: £49.99
The standard horn supplied with your Triumph is rather quiet The trumpet horn develops 109dBA at 410Hz and is loud ldquo CE rdquo Market and fully
Loud & Proud pair of Rivco dual tone horns. Electric Horn Set super loud horns and relay kit.
With an output of 118 decibels these are the loudest electric horns you can buy, over three times as loud as most stock horns and a great economical choice.
A direct replacement for most 12-volt electric horns. The set includes two chrome finish horns (one high and one low tone), mounting brackets and installation instructions.
You will need to consider access when fitting these. Crash bar mount is Ideal but space may be an issue with certain types of bikes.
ELCHRN – Magnum electric dual-tone horn set with chrome finish.
Product Code: ELCHRN Category:
● Produces a dual tone 118 decibel blast
● Uses stock horn button
● Available in chrome
● Backed by a one year warranty
● Compact horns are easily hidden
