alselec .060 Over Joined Aug 11, 2006 Messages 162 Sep 24, 2008 #1 Anyone have the Rivco center stand? Do you like it? Does it scrape on corners?
Bishop Turbocharged Joined Sep 24, 2007 Messages 824 Ride 2005 Rocket III Sep 24, 2008 #2 Do a search, I think you'll find a 50/50 mix on opinions about it. From what I understand, getting it mounted may require some cutting and/or grinding as not all Rockets were created equal. Personally, I don't see the need for it.
motorat .020 Over Joined Jul 27, 2008 Messages 30 Sep 24, 2008 #3 i have one that you can have for $200.00. it does not work with the r3t. one issue is that the right side has 2 holes and the more rear one is stripped out but it could be drilled out and a longer bolt used. might be worth saving $150
alselec .060 Over Joined Aug 11, 2006 Messages 162 Sep 27, 2008 #4 motorat, does your stand work ok, any scrapes on corners? The Gold Wings and others have them so they must able the be lifted and work ok on corners.
