PaddyO
I took out the battery to get load tested at the Batteries Plus store. It is a Deka battery, which I believe is a well made battery. There was a 1/17 sticker on it which I think means it was installed on January, 2017, almost 2 years ago. The load test showed it to be on the low end of the "good" range. I decided to replace it anyway as I am trying to rule out a possible cause of this apparent overcharging. I replaced it with a Duracell DURAGM-20L. I put it on the trickle charger for about 12 hours before testing and using. I also got the Optimate tester for Cranking Power and Alternator Bedifferent suggested. Before starting the bike, the voltage in the green with the Optimate, and my Gearingo gear indicator is showing 12.7-12.9 after turning on the key. When starting the bike, the Optimate shows the voltage drop to be between 9.5 and 10 volts, which is good. At idle, the Optimate is indicating the voltage is varying above and below 13.5 volts. The CVS is flashing slow green which is between 13.2 and 14.6 volts. Once the revs increase, either at idle or on the road, the CVS is flashing a fast green (more than 14.7 volts) and the Optimate is showing more than 14.5 volts and also flashing red indicating more than 15 volts.
@DEcosse, is it possible for the rectifier to be bad? Or is this something not to worry about?
