PaddyO
I replaced the stock rectifier on my 2014 R3T with the SH847AA Suzuki rectifier. I have the Clearwater Voltage Sentry also mounted on the bike. The CVS monitors the condition of the charging system. it uses a single LED to indicate the state of the system. From their website:
Flashing Red: Indicates Less than 11.5 volts (12.7 volts on Shorai battery). This is not a good condition for the battery, and could indicate a starved or defective battery. Get a charger on this battery immediately and check to see if it will come back to life.
Solid Red :Indicates between 11.6 and 12.0 volts (12.7 and 12.8 volts on Shorai battery). Weak battery, start and run the engine for a while or get a charger. If this persists after charging, the battery needs to be replaced. If this occurs while the bike is running, your alternator is bad or severely overloaded.
Solid Yellow: Indicates between 12.1 and 12.4 volts (12.9 and 13.1 volts on Shorai battery). This indicates the battery needs to be recharged. If this occurs while the bike is running, it means you are drawing a lot more power than the alternator is generating, and potentially a bad alternator.
Solid Green:Between 12.5 and 13.1 volts (13.2 and 13.4 volts on Shorai battery). Good battery condition with the bike off; poor to weak charging condition with the bike running. This can also indicate your accessories are drawing too much power. Note: some bikes do not generate sufficient power at idle. This can be normal. If you get the solid green light while your bike is idling, run the engine faster and it should start flashing green.
Slow Flashing Green :Indicates between 13.2 and 14.6 volts (13.5 and 14.8 volts on Shorai battery). The battery is charging properly.
Fast Flashing Green: The battery is over 14.6 volts (14.8 volts on Shorai battery). This indicates an abnormal overcharging situation that could indicate a faulty alternator. Get your electrical system evaluated immediately.
With the OEM rectifier, I always had a Slow Flashing Green light on the CVS with the engine running. Since installing the SH847AA rectifier, after starting the bike, the LED will be a Fast Flashing Green. After riding the bike for a while (20-30 minutes?), the LED will change to a Slow Flashing Green. Also, when turning on the bike, the LED will be yellow whereas with the OEM rectifier, the LED was green.
Is my battery going bad? Is it a coincidence that this change occurred after installing the SH847AA? Is the SH847AA causing a problem with my charging system?
