I've been BUSY lately. A GOOD thing.
Specific to the R3, I don't offer anything in the way of performance, just PCIII or TuneBoy and K&N filters. I am working on: 1.) an R3 specific air filter system with integrated velocity stacks - in 'glass or carbon. 2.) An aftermarket engine management system that is plug-and-play for the R3 - mostly for the supercharged/turbocharged guys. 3.) A stand alone active knock control system for the R3 - again mostly for the forced induction guys that do not want to go with a full engine management system.
I will be ceramic and dry film coating a set of stock R3 pistons later this week - as soon as they come in. These are for a supercharged R3 owner.
Tuning:
I own an eddy-current dyno that allows me a bit different operation than the old DynoJet would allow. So my SOP is a bit different than some others. No Tuning Link emulation, I make adjustments based on gas analysis and what the engine wants for best horsepower/torque - each engine will be a bit different.
After a warm up loading to get the engine and oil temps up, I normally step test every 1000 rpm at WOT to set a base line with Tuneboy.
Then I set up to step test every 500-1000 rpm (depending on the bike), and test each rpm point at varying throttle positions - making changes to the base tune in TuneEdit as I go. All based on what the gas analyzer indicates.
Shut off the engine, and load the changes. Go back and test again - repeat until each region is close on fuel, ignition advance, and cylinder stagger/offset. When the torque and HP readings show that fuel is optimized to what the engine wants, it is time to test ignition advance, and fine tune fuel for what the engine wants based on TQ/HP over a wide range of throttle positions and engine speeds.
Once correct, I tune the idle and cruise regions for leaner cruise conditions - for improved fuel consumption. In some cases, I go all the way to lean misfire, and then back off, but the AFR tales need to be reworked to allow this - or the Lambda sensor turned off.
I then test transient response at different loads/engine speeds and adjust the MAP tables to get the acceleration enrichment correct. Some of the TuneEdit maps (for some bikes) also allow adjusting the TP/MAP correction factors at different engine speeds. This sets how sensitive the ECU is to MAP sensor enrichment, and how it tapers off as engine speed increases.
I test and correct at normal and a bit hotter than normal engine and oil temps to make sure the tuning is correct for various riding conditions.
Final testing is done for a graph, while watching engine and oil temps.
Normal tuning SOP for most good shops.
I have 2 different R3s scheduled for TuneEdit tuning on Thursday. Both bikes have different modifications - one is cat delete, TORS, and undertank K&N; the other is Jardines, 3 K&N under bearclaw. perhaps they will put the final tunes up for others to download. I will ask. That is up to them - they will own the tunes, not me.
-Wayne
