Got the plx kiwi wifi working tonight. Found out from the rat site that I had to jumper pins 4 and 5 to get the device to power up. Not all PIDs got monitored, but dascommand did detect MAF, MAP, fuel flow, rpm, ST and LT fuel trims, IAT, coolant temp, gear selected, and engine load. A/F ratio and lambda are not directly read, but it will calculate a/f from o2 trim, fuel type, fuel flow, and MAF.
By entering final drive ratios, weight, and tire size, the application will calculate HP and torque from the accelerometer on the iPhone or iPad.
You can store the data log for your ride and then import and replay using PLX logger software.
With a full list of Triumph PIDs and scaling factors, you can create custom parameters to monitor beyond the defaults.
This is potentially a very powerful tool for live dyno tuning on the road. Imagine being able to do a track run, log the data, tweak a tune in TuneECU, download, and repeat the run. With enough effort one could optimize each cell of the L and F tables for economy, power, and eliminate decel popping.
Need to do some more testing, but that's the early review for now.
