The O2 sensor is turned off.
The 12 minute tune is basically required whenever you reflash the CPU (loading a TB program), whether it's warm or cold. You can do it for any other reason though, even for climate altitude changes.
I more/less just found this out. As a result my idle is pretty rough and down by about 100 rpms, and lopey.
The problem is the bike needs to be stone cold to kick it into the 12 minute tune (which is really a 20 minute tune for me, b/c I believe the proper countdown is after the first fan comes on, and mine takes a long time to come on, even in 80 degree weather.
The bike still feels chuggy down low, so I'm going to add another +5 points of fuel at 10% TP between 600 and 2000. I think I need to add another +5 acroos the low rpm/TP spectrum, but don't want to make too many changes until I reset the idle tomorrow.
I also added +5 to 0% throttle at 1800 rpms to reduce a few pops in that area. We will see tomorrow :wink:
