Picture needed
mcycle
Standard Bore
Louisiana
Need pic of roadster wheel were it meets final drive.
Took the wheel off and it look almost like the spline is not full set when putting it back.
Should have taken a pic before
2012 roadster
thanks
If the wheel fits in with the spacer on the other side and the caliper lines up, it's in properly.
Dunno if it helps, but from what I can remember on my 2013, it just slid right in. Gave it a little twist back and forth, to make sure it was aligned with something, and the rest went together no problem. If you had to force the spacer in, then I'd worry.
