barbagris
Mad Scientist
- Joined
- Aug 1, 2010
- Messages
- 12,988
- Location
- On the verge of insanity
- Ride
- 1979 Guzzi V1000G5 - 2018 KTM 790 Duke
So 0,201 is 5,1054mm - The drill size for M6*1 ISO is 5mm. 6mm being 0,236220472. Good to go.after pulling the pin 1/4- 20 was the closest size bolt that would work as you need material in the hole for the Tap drill size. In this case .201/ it also was the closest to the original pin diameter. So any metric thread not exceding the .250 major diameter will work. The actual OEM pin diameter was 5.96 mm
5,96mm sounds like 6mm to me.
