Gents,
Please put your hearts back in your chest and don't wear them on your sleeve for this. Huge thansk to Dyno Steve at
DynoSteve Performance for the inexpensive dyno time, chatting, and for allowing me to wrench with the bike on his dyno and get these tests for us all!
Please remember today was MORE ABOUT THE V-STACKS than the pipes!!!!
As a result of today's efforts, I'll be publishing my 3D design for anyone to order and use. I make not a single cent, its all worship to the gods of speed!
First off: The bike needs to be tuned, as delivered it was super fat from New Jersey, it still is, but swings lean at high RPM. There is more power once tuned, I have an appointment on the 10th to get it tuned, so these numbers will come up some, of that I have no doubt at all.
The most interesting part, I can
FEEL a big difference on the bike vs the CES headers, which means, there
IS a good bit more power than with CES, but the numbers don't match up to what I was given upon delivery so, I
caution against directly comparing the actual numbers, instead compare the curves of today's dynos and the Carpenter dyno.
Three tests were run seen below:
Run 05: PX-500 Filter, Velocity Stacks
Run 06: Velocity Stacks
Run 07: Open Throttle Bodies
This run is as I delivered it for dynoing, PX-500 filter in place, running Shell V-power 92 octane I got on the way to the dyno.
Filter removed and stacks left in place, NO other changes were made, runs were about 2 minutes apart, as expected it made a bit more power (+6.2hp/+6.8lb-ft):
Now this is THE most interesting plot. This is allegedly the "best" way to make power, well frankly, it's not!! Going from open stacks to open TBs (-4.2hp/-10.7lb-ft). Again, about 2 minutes apart, NO other changes were made.
This is all of them layered together, and I asked him to include last year's dyno for ****'s n giggles. MOST notable here, you can see the telltale carpenter 265 torque dip at 4800-5000 ish, something that's almost completely eliminated with the stacks in place. More to follow on that after this:
Finally, this is today's run with open stacks overlayed against my Carpenter sent dyno plot. If you look at the shape instead of the peak numbers, you'll see that LES exhaust coupled to the stacks is making a broader flatter curve that carries up top just as well as the Brute pipes did (to 8200, my hard limiter).
The comparison of the shapes, the fact my bike's now lean up top, weather, and dyno calibration differences between two dynos in
my mind, settles this as a complete success, with more power on tap when the bikes re-tuned. The number may be 10.9hp behind, but I would bet a significant amount of money, if I strapped my bike as it sits, on Bob's dyno with no changes, the numbers would be nearly identical to what he originally sent me.
EDIT: Improved accuracy of final plot overlay.
