Ridefree
- Joined
- Jul 11, 2012
- Messages
- 352
- Location
- St. Petersburg, Florida
- Ride
- 2013 R3T .... 2003 Harley softail
So today i was trying to crimp the low tension coil leads to make them a little tighter, as preventative maintenance, and broke the female connector while trying to push it back on. those things sure are flimsy. I was working on the coil up in the neck. wires are so short and space is so hard to work in. I was thinking of removing the coil and soldering a six inch wire to each mail spade with heat shrink and soldering a connector to the end of each of those to plug in to the original coil wires. this would bring the connection out of that corner and easier to work with. I could solder on a length of wire to the existing wire with a new female also but i was thinking of trying to improve the situation. I don't want to use crimp connectors to add the wire as they have a habit of loosening up over time. Has anyone come up with a quality fix for this that might be better than what i'm thinking
Thanks, Ridefree
Thanks, Ridefree
