tekardi
.060 Over
Buenos Aires - Argentina
Today after I road my bike notice a small oil drop from here ...does anybody know if this is normal
From that black sensor? What is that? Thank you
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
:rolleyes: mine is the same although not dripped as yet,just moist.i will see if it gets worse before i start pulling it out
no picture buddy where abouts on bike are we talking about?
This sensor from beneath the oil tank left side of the bike side by leg stand thank you
still no picture But I am guessing it is the same area as I had a small leak give it a real good clean and keep a very close watch on it but more so the lower engine case bolts cos that is where mine was leaking the dealer waqs baffled by it and triumph Auss was ready to send a new lower case but then we tried replacing the bolt and fixed it, seems the original bolt had tiny bit to much clearance in threads and oil was seeping thru, hope this helps, the bolt is very close to the sensor you mention and was our first suspected point of leak
So far my only experience with oil leaks is from my old shovel head Harley. The rules for those are, as long as the puddle is not growing by more than 6 inches an hour there is no need to even look for the source. The time to worry is when it stops leaking :D
Just noticed mine is weeping from the same area :/ did u manage to solve yours
Sent from my iPhone using Tapatalk
That looks like ya gear position sensor it could be a hardened O ring that needs replacing if not and its coming through the sensor somewhere I guess you have to replace it.. probably just the O ring :)
