HeR3tic
In my experience, with a cold soaked and dimminshed battery charge, the tach sweep still goes along with the speedo sweep....Would a marginal battery cause the tach needle to NOT sweep when the ignition is turned on?...
Tighten your battery connections. The 5 second crank then nothing leads me to this assumption.
So you replaced your handlebars did you. The 5 second crank could in fact have been a 5 second burn. Pinched and burnt and now grounded wire??
Put some dielectric grease in those empty sockets and let 'em hang.
BTW, I purchased an upgraded battery (310CCA) after only a year on the original. The new battery also suffered from cold soaking over a weekend of sitting, with overnight temps down into the 20s. I don't have the luxury of a heated den to pamper the fat bottom girl with. I could roll the beast out into the sun and after a few hours with 40 degree warmth it would fire right up. Or a ten minute charge at 10 amps would do it and I wouldn't be late for work on Monday. PS. The old battery was deemd serviceable. Just cold hearted.
