RoadVenture
.060 Over
- Joined
- Sep 18, 2007
- Messages
- 186
It was a rainy day so since I was unable to successfully get an extended front brake hose i decided to put the stock handlebars and cables back on so I would be rady to ride when the rain cleared eventually. Not being satisfied I also decided to install my Electrical Connection fuse block so I could use it to run my GPS and future Moto Lights. The handle bar re-install went fine. The fuse block install went fine. I put gas in the tank and started up the bike. Oops, it didn't start.
The ignition went on, both the speedo and tach did their needle sweeps and the indicator lights flashed on and off.................normal. No neutral light. Pull in the clutch and I pressed the started button and it cranked for maybe 5 seconds then stopped cranking. I pressed the button again and nothing.
Key off, key on. The speedo needle did a sweep, but not the tach. Tack indicator lights flashed and the oil light came on in the speedo. Pressed the started button again, cranked two times and stopped. Now the oil light is on PLUS the orange "engine" light.
Key off, key on. All is the same as previously described before, but now there is no cranking at all.
Key off, key on. All the same as before, No neutral light (trans is in neutral)
Does anyone have any idea what I am doing wrong? Please feel free to tell me that I am an idiot and have done the equivilent of forgetting to turn on the fuel petcock.
