Welcome from New Jersey, Mate.
The Rivco center stand is an overpriced POS that has fitment problems (inconsistently spaced mounting points). It is to be avoided unless you want a DIY project .
Meanwhile, enjoy the ride, Captain!
Welcome! From New York USA! No center stand yet except that POS from rivco! Now there is a stand that is made by flipmeister which is used for maintenance. It is made to take on and off and uses a cam action to lift the bike up. I dont even know if you can get the R3T up on a center stand its so heavy! :D At the top of the page is a link to his site. Several of us use it and it works well.
mutt
Welcome from the original OZ. Yeah showing up late to the party you get the left overs. :D
hi all ,why do i have to let the clutch a bit to get in to 1st .
Can you be more specific? I would say not pulling in the clutch at all would make getting into 1st gear a dicey proposition (depending on what you're aimed at).
Check your clutch play is correct (2 mm).
When I saw Hellfire's post I knew this was a necropost. I imagine he is talking 1st from neutral, for some reason it tends to pop out if you go from neutral to first, I also let the clutch out a bit and keep the shifter pressed, it works. Never a problem from second to first, only from neutral, no idea why.
