SO here I go with the dreaded high idle. I read as many posts as I could and get as many different causes as posts I read. So can anyone shed light on my issue with the following information:
1. New stepper motor installed and throttle bodies balanced.
2. Crank angle sensor under motor cleaned twice, to be sure.
The bike is a 2009 Classic with TORs, Triumph TOR tune, PCV, GIPRO and under tank K&N. All has been fine in life until about 2 months ago when the high idle started (@ 1200 - 1500 rpms). The bike has 17,000 miles on it. Took the bike to the shop and they diagnosed a bad stepper (which I doubted) and they replaced it a month ago. It has continued the high idle problem ever since. Last night was the final straw as it revved at 2000 in neutral in my driveway and would not drop.
More facts:
1. The high idle will drop to correct idle in @ 20 seconds if I sit in neutral with the clutch disengaged. Will become high again as soon as start riding from the stop.
2. The high idle will stay if I sit at a light in gear with the clutch pulled in.
3. If I shut the bike down while high idling, it will start at correct idle.
Any ideas guys? Thank you for any help. As I mentioned, I've read a ton of posts but I'm hoping someone can shed light with my specific description here.
