New Handlebars
Joker
Turbocharged
UK
Following a suggestion from Fin I've just fitted these bars from a Hardly Nightster (or whatever they're called).
Thanks Fin, top tip. They have less pull back, and are lower and narrower, which is just what I needed. In combination with the Corbin dual touring seat and TTS's rear sets they give the best solution to the problems of trying to hang onto the bars coz of wind blast at high speed and stopping yourself from sliding onto the pillion seat under hard acceleration.
I'm now torn between the tear drop and oval mirrors to replace the stock ****e items. I was going to go for Kuryakin grips but some have reported problems fitting them. I also need new bar end weights.
All suggestions gratefully received.
glad that you are happy, I put original weight in plase. just buy same diameter rubber tube ( hydraulik tube ) then use long screw and 2 washers and 1 nut .
a) assembling order first take weight in your hand put long screw after that put one washer, then cut tupe about 3-4 cm piece slide that in the screw and add that other washer and nut..
b) slide that "system" in your handel bar and start to turn that bar end screw .
that rubber tube start to expand between those washer
I hope that you realized what I mean.. If not I can take picture
