Funny! The wire you want is normally attached to the metal bracket behind the plastic accessory plug panel. The wire you need is pink/yellow. It is attached to a three wire triangular plug with two other wires (black wire and black/yellow wire). I used a Posi-tap on the pink/yellow wire, worked real well and allows easy removal if need be.
