need help with tuneboy
Note . When you use tune software it is most important that you have a copy of your tune before you use Recover from failed download ,this is even more a must if you have a custom tune ,The reason being after you select recover from failed download it wipes your ecu and finds the tune best suited to your bike from the system and installs it into the ecu.
i didnt back up my tune recove from failed download not available :(
Do you have the new type of tuneboy or old type cable only
Don't know what old looks like i got it couple days ago probably new one
You need to get the tune for your bike type . open tune and save so you have that map open to load into ecu.
connect battery to charger if not fully charged
switch on bike then open tuneboy ,download tune box should turn yellow .
select and tune should load into ecu, follow promts.
should load or say failed .
select and tune should load into .
Ok i never did it that way what i was doing is open map and download maybe its what i was missing Thank you i'll try it that right after work thanks
Ok i start tuneeditor open tune that i want try to save it and massage pops up failed to open output file!!!!!!!!!4 ?
Im loosing all hopes here :( is there anybody that i can send ECU to and maybe they'll do it for me ?
God help you!
Any authorized Triumph dealer should be able to forcibly adapt your ECU back to factory settings.
My experience with Triumph dealers is such that I am forced to adpt some prayers on your behalf.:x3:
