wilk
.040 Over
Ok i got P1614 ECM or tune ID incorrect codeOK your tune edit is having problems but the tune boy dash is what you open to check error code and run diagnostic test not tune edit. Now that being said you should be able to open the tune with tune edit and not hooked up to the bike if it does not recognize the tune with tune edit then you probably do not have the right tune if it is a normal tune if it is the custom multi trim style map Tune Boy would make it so only your tune edit will open it on your specific ECU and no one else. That set is 500 bucks or so and employs a wireless link up made in conjunction with the wide ban O2 controller from Innovate.
