My Bearclaw Mod
vindex1963
Turbocharged
Payson Arizona
2006 Rocket 3, 2015 Victory Cross Country
Might help a little with performance getting some cool outside air instead of across the engine hot air.
3" hole saw is a ****** to use with no two surfaces being level. I guess the chrome was hard to cut because when I was done
the Milwaukee Hole Dozer was destroyed. I also used my Dremel and a carbide end mill to rough the holes imperfections then a sanding wheel to clean them up. I used 1/8" hole size stainless perforated sheets and cut the screen just over the hole size. The Claw was scuffed with a sander and primed. I'm going to paint the Claw with black truck bed liner and over that use Plasti-Dip. The screens will be painted as close as I can to the red of the bike. Should have a really good look.
The screens are just a mock up for now.
OHHHH ok, im looking for options to make my filters look good
Have a stock one 'X'ed.
No holes or just slotted for your big K&Ns. Bare metal or a Black roadster one.
Do the Grinder swirls as stripes and then clear coat.
Or..... get my NOS RocketX rear fender and make that custom flyscren and use the rest for a custom bearclaw. ;)
There are a few bear claws around, I think I even saw a factory bare metal version with its own part number once.
Looks great!!! What size filters can you fit in there?
3" ..... but its the length that counts! ;):roll::roll::roll:
You still need to have them line up with the TB holes either directly or offset as available from K&N and others Tapered cones may be best.
I recently re-posted Mittzy's great drawing and measurements of the throttle body spacing, diameter and spacing etc..
