Molly 60 to be discontinued
It was very thick an adhered very well to the metal surfaces. Until someone says it's an absolute myth, the Loctite is on my splines, and I know the mechanic because he looked like a red neck hillbilly I've known for a long time . Nothing stirs up more conversation than grease and oils.
Note the word LUBRICANT, easy Jim. I was going to ask about how big the bulge was on everyone elses lower radiator hose onto the water pump but I thought that Jim might only speed read bulge, and lower hose and start doing selfies and get thrown off the site.
Got a message from the Amazon mob that they had to cancel my order due to being out of stock so where did you say you got that Loctite Moly Paste
The dry molybdenum disulfide is what's doing the job, I'd say, the rest is there to make it easier to manage and to help a little, I guess. The more moly the better.
Hans - can I include in your order if you get one from OS?
What little bit of research I have done this look like the best to me anyway
same here!!
I got a cancel from Amazon also... I've been calling around to all the Triumph dealers in the area couldn't believe what some of them are using to grease the splines.Makes one wonder about the final drive failures.... The one dealer that i trust is using Maxima water proof grease. http://www.maximausa.com/product/waterproof-grease/ as much as i like the service there i'm going with the Loctite Moly Paste 51048 Honda has replced the Moly 60 with Moly M77 still about 300 degrees less than the Moly 60.
