key switch ignition issue
Fixing the ignition switch costs nothing if you can do the work yourself. You will need to remove 2 tamper proof screws and replace them with regular metric replacements, and solder a wire or 2. However, the problem will return if you don't fix the issue which caused it.
@DEcosse's system is excellent.
LED bulbs which draw less power is another option, and a keyless ignition in addition to that is also an option.
Eastern Beaver also make a bypass kit.
A cheap redneck bypass can also be found in my signature.
