you are not going to solve problems by changing the clutch switch unless the switch is shorted out. and you can check that by trying to start bike with out pulling clutch if bike starts w/o pulling in clutch lever then clutch switch is shorted and will cause motor problems.
a lot of guys have removed the stepper motor and liked the way it worked i had problems mainly because the motor was not hot (when it got hot it just started gaining rpms ) so i reinstalled it and had to give it throttle till it warmed up. of coarse it works great when warm.
spray throttle linkage to clean and unstick throttles especially at front. while cleaning do wot and let throttle fly shut.
If the problem was just the idle it wouldn't bother me, the bike still idles OK enough, at the moment I believe the idle is just a symptom of whatever the real issue is, which is that the bike leans out and loses power. I'm just eliminating potential causes one by one and the clutch switch impacts mapping so I want to eliminate it, when I get a chance i'll unplug it and make another manual switch to test. The surging isn't a huge issue either, but the thing I love about the bike is the insane power, if that's having issues it needs to be addressed.
Whatever the issue is I imagine when I find it both the surging and the idle issue will disappear, fingers crossed anyway.
just start it up disconnect and try it that should make it like normal.
that might set a code
best a button that closes the circuit.
Interesting but way beyond my meager comprehension. Follow thread for outcome !
