Willtill
Nitrous
Hi all,
As some of you know, I recently removed my cat box, and installed a cat bypass. Also loaded the 20219 tune via TuneBoy (Rocket Classic with cat bypass and aftermarket pipes), with secondaries at 100 percent. Stock silencers are still installed, as well as the stock intake.
Here at the Cancun Cantina, they had a bike day, and I was lucky enough to get American Cycle Performance to give me a free analysis of the current setup. Below are the results:
As you can see, the blue line in the below graph representing air -vs- the fuel is much more pronounced @ 2200-3200 rpm. They recommended that I needed to enrich the mixture.
From reading on Tuneboy's website, Wayne recommended that to enrich the fuel mixture; all values in the below AF table can be selected and the ratio's reduced to attain this result (richer mixture).
Link Removed
The AF table I posted below is from the 20219 tune. I am thinking about selecting all the cells in the AF table and dropping all the values by one whole number, to match what Wayne is talking about
I don't want to mess with the F1 -F3 tables. I am thinking this would be the best way overall to enrich the fuel air mixture. Thoughts?
Link Removed
