Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,832
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
If you can remove the oil tank without removing the throttle bodies, then make sure you let us know how.
The TPS can be changed easily in a couple of minutes, despite what the manual says. You will need a Torx bit to unscrew it, but do not use a socket driver to turn it. Get a small spanner , or wench, and use it on the hex shaped part of the torx socket, while pressing the torx bit into the bolt. Don't over-tighten it when putting it back in. It just needs to be firm enough to hold it.
I replaced my torx with an allen head. Much easier to deal with.
