loftyjohn
Standard Bore
Hi Gang
When I switch on the ignition the 2 clocks sweep and the neutral light shows green. All works fine.
If I switch off for a stop leaving the bike a few mins, then switch on again the 2 clocks sweep and the neutral light shows green. All works fine.
If I switch off and on again quickly only the speedo sweeps, no tacho sweep and no neutral light.
If I repeat again, sometimes it resets to normal and all works fine, but occasionally the speedo goes strange as well, sweeping but only returning to 30mph instead of 0.
I leave a few mins and start again, all works fine.
The bike still runs and rides ok in this glitched mode without tacho, neutral light and speedo running from 30.
Nearly for got the trips reset to 0 every time it happens
I find I am learning to work around this glitch, but surely this is not normal.
Anyone else had this or any ideas?
Ps whoooa what a bike, lovin it
