install tach and volt meter (digital)
Just thought and it did not hurt. But when you hook tune boy or tune ECU to a Touring does it have a tach on the software dash? If so some how that signal is getting from the ecu to tune tune ecu or the OBGYN Plug :)? kind of makes you wonder!!!!!!!!!!!!!
I wonder with a digital dash app and BT OBDII plug if you'd get a tach reading. Obviously we do on the classics, just wondering about the touring?
An app like Torque with a BlueTooth connector plugged in to the OBDII port will give you a tachometer, and a bunch of other stuff.
IIRC somebody was getting great results from a SCANGAUGE-II thingie.
I have a Virtual Instruments OBD2 plugin thingie - Problem is the display is near invisible in strong sun. Most cellphone displays are too.
Don't expect Full ODB-II from an R3 though - It's OBI ONE CAN NO BE. Well it might be OB1 and a little bit on maybe not quite.
If TuneECU shows a tacho for the "T" then Torque/scangauge etc will too.
Skip to 3:12 in the video to see an easy way to get multiple gauge readings including RPM ,Voltage,Temp,etc,
Skip to 3:12 in this video to watch an easier way to get RPM,Voltage, air & engine temps ,Throttle position,etc,etc,,,,
@Macrider
Thanks for the video.
I have asked this question before, but can't remember if it was to you - if so, pardon please.
Do you leave the OBDII pluggen in always?
Do you experience any battery drain after not riding for a time?
Well one bit of info Wire Connection:red-positive,black-negative,green-ignition
If it were me I'd start by attaching the RED and Black wires to the battery as indicated above , wrap the green one around a plug lead and fire the beast up in the garage.
It'll either work or won't. Let us know and we'll plug on. Pointless looking for where to wire the blighter in until we know it works.
btw - do you intend to let them get wet often? - I'd avoid it if I were you. Gut reaction to seeing rust on advertising photos.
thanks for all the input, I hope to be able to go out to the garage to try out the spark plug wrap on saturday, ill let you know if it works out
now that garmin is a cool unit. At the risk of sounding really dumb Ill ask anyway, but is this thing compatable with a R3? or does the R3 have a OBDII or similiar? ive honesly never looked. I do have a power commander installed
