atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 4,302
- Location
- Keller, TX
- Ride
- 23 Rocket GT, 20 Bobber Blk, 22 Speed Triple RS
Maybe I'm blind but it sure reads like the same problem. Loss of contact in the electrical circuit. The relay failure is fresh, more likely the gate was corroded (switched fine but to a bad terminal).
If you spend a little quality time with the schematics you can narrow down your problems to a couple easily tested possibilities. Anytime you fiddle a connection and it suddenly works thats telling you something you need to listen to. The connection is loose where it counts. Ignition switch replacement doesn't solve a problem if the problem is the solder joints over heat and break loose. I advocate first understand the problem, then fix it. A lot of shops fix the symptom and rarely look for the problem.
When my Trophy 1200 started acting weird and I was at a loss I took it to the dealer. They had it for 3 weeks. They tested all manner of stuff over three weeks. (They even reorted to using a spare $1100 igniter to test my problem). They finally found a problem in one coil. Replaced the coil, everything was great. But they had to test every circuit and ignition whatzit until they were down to the coils (maybe should have looked there first?).
If you need some help deciphering the electrical prints in the manual just ask, someone (including me) is always willing to help.
