I checked my oil today, sitting on bike upright, and no oil was registering on the dipstick. I got very concerned about this and checked it a few times with the same result.
So I immediately got some oil which I had close by, and emptied about 400ml into the engine thinking that would do the trick. I checked the oil again and still no oil on the DS. So I got more oil and put in about 200ml more and still nothing.
I did all of this without starting the engine first because I'd read on a website that it doesn't make any difference whether you check the oil cold or hot. So I went back to the bike, turned it on and let it idle for a couple of minutes. When I checked the oil again, the level was sky high, about an inch or even more above the max level mark.
Now I have at least, 600ml more than i should have in there, but after a very long, hard ride, I didn't experience any problems, or leaks and the bike ran fine.
Bottom line is, should I be worried about this or can I just let it ride? I've also read that because it's a dry sump, overfilling doesn't hurt the engine. Can anyone confirm this or has anyone done this with or without negative effects?
Many thanks.
Many thanks.
