I know I'm a sign nut.
Boog
Traveling Story Teller
Dumfries, Virginia
2014 R3T, TORs, RAMAIR
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
you can always tell when an OSHA person shows up because they are the ones that know absolutely nothing about your business.
osha rules were 40psi max air pressure and it takes 100 to 150 psi to air check a transmission
normal pressures r 60 to 125 and 250 in reverse
in fail safe 250-350
and if regulator is stuck it will explode cast iron drums and break aluminum pistons
i was checking a car with high pressure and a 300 pound gauge and when the transmission malfunctioned it peg the gauge and the hose swelled up in my hand
idk
Maryland
Royal Enfield Bullet
I have some AAA batteries and the instructions say to wear ANSI approved goggles when changing them.
My theory is that most warning should be removed. If you need to be told not to use a hair dryer in the shower then you shouldn't be passing on your genetic information.
