I have used these Posi-locks before and seen them fail! They are not bad for low current draws but that is all, properly soldered joint is as good as it gets, you don't need to worry about poor contact, mind that is as long as you make sure you do a good job of soldering the joint I also heat shrink and where possible in multiple layers then also give a good wrap of insulation tape
