Front Rotors
If it was fine and then suddenly shaking... I wonder if you might have lost a wheel (balance) weight, causing the shake. Just a theory.
They are snug all right. There is a lot of play in the thingy joints that make them floating discs. As far as the fork leaking. Where do you pour this SealMate product?
It is an inexpensive thin piece of plastic that you slide between the fork tube and the seal cover, then slide around the fork circumference.
It will remove dirt and scum that may be causing a leak.
Well worth a try IMO.
The adventure continues. Is the top of the yoke tube flush your outer tube top lip? Huuum? Mine are not. The lip protrudes over the top of the yoke , on both sides. Is it possible it has been like that since it was born?
I have not lost a front tire weight. We will place it on the balancer to make sure.
The wobble is at slow speed. Lets say 5 to 10 mph. The thing is that the way the Triumph shop wants to work is; "leave the bike and we will fix what ever is wrong. What is it doing that makes you think it is a problem?" NOOOO, I have a problem with that. The person taking the intake order has never held a wrench in her hand. Not leaving my bike there on those terms. Going to work with my Valkye tech. Remove the front tire, loosen the top and bottom koke pinch bolt. Reset the fork tube in the correct position. Tighten the pinch bolts, as it has been suggested here before. Then, there is a procedure to set the head bolt torque. The handlebars have to come off. Then, see if the bike is straight and true and does not wobble.
If that don't fix it Ill cry
The don't rattle unless you grab the disc and push it clock and counter clockwise. As far as heat, going downhill in the Smokey's, the'll get hot even with engine braking. It's not going to be red hot, but they will get hot.
I have a SealMate around here somewhere if you need to use one.
Can't help with the rotors though, sorry amigo. Looks like you have some of the more knowledgeable R3 guys chiming in though.
And quit chasing me... pass me!
FIRST IF U GRAB THE ROTOR AND CAN PULL IT OFF BY HAND THEN REPLACE IT IF NOT DON'T WORRY ABOUT IT.(SORRY CAPS)i worried about mine for years and checked them all the time now i don't even check them.
if it wobbles at 5 to 10 i would check to see if the beads r properly seated. maybe get the front wheel of the ground and rotate it while watching.
unless u have run the pads metal to metal i would think they r all right. u can always post a pic.
i would not put thinner rotors the ones on there r thin enough
the wobble that most of us r familiar with happens around 45 mph. which is a front tire prob. i just kept my hands on the bars all the time and this last cobra has a small wobble but i just keep the hand on the bar and there doesn't seem to be a prob
ps i think my forks r a little more down but if it was mine i would think if it is not broke don't fix it.
I had about the same problem with low speed wobble/wallowing after installing a new front tire. Front tire checked OK for balance and true for round. Checked the front forks for play- checked OK. Everything seemed good so for Sh!ts and giggles I retorqued the head bolt IAW the maintenance manual. Problem solved! No more wobble/wallowing at slow speeds.
Reactions: 1K9
